March 24, 2021 at 8:49 am
Juli
SubscriberHello,
for the assessment in our Finite Elements course, we need to perform an analysis of an elevator torque arm (Cessna 182) in Ansys APDL with the following description:
"It had been hypothesised that a good approximation of a bearing load can be created using a Pressure - on Lines type loading. You have been tasked to check and see if this is the case and hence prove or disprove the hypothesis. To make the process as efficient as possible, the geometry shown below should be used to test the hypothesis"
Viewing 0 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
