3D Design
3D Design
Bend microstrip antenna
    • shashank1
      I have a micro-strip antenna I would like to bend the antenna at small angles in HFSS. Can someone please explain how I can bend the antenna in HFSS.I cannot use wrap command as it can be performed only if one object is sheet.
    • peteroznewman
      Does HFSS use SpaceClaim?
