Bending analysis of microstrp Patch: while bending the antenna which includes shorting posts
    • tiwariar
    • Praneeth
      Please share screenshots of your model and the error in the message window to help us serve you better. Kindly note that Ansys employee cannot access any of the attachments in the forum.
      I can assure you that you are using correct method for wrapping the antenna.
      All the very best.
    • tiwariar
      Ok sir.. I have already shared with the previous query in the word file... sending it again
    • Praneeth
      Please clone the intersecting materials once and subtract them from the objects that they are intersecting. This is required after wrapping the objects.
      Are you using lumped port? Can you highlight the port in your model?
      All the very best.
    • tiwariar
      Thank u sir...will try this....and sending u screen shot of
      highlighted lumped port...
    • Praneeth
      You can use wave port instead of lumped port by extending the feed trace to the antenna or you can increase the size of the lumped port along z-axis.
      All the very best.
Viewing 5 reply threads
