September 11, 2019 at 2:01 pm
MaximilianSauer28
SubscriberHello, how can I construct a bending-beam as a square-tube (l x b x h = 2000 x 50 x120).
The straps (thickness = 9mm) are to be displayed as solid-elements and connected to the two webs (thickness = 2mm, height = 120mm) laterally. The webs (height = 120mm) should be connected to the lateral surface of the solid-elements as shell elements (common surface)
How can I realize that in Ansys? Pleas help me
September 11, 2019 at 3:31 pm
SubscriberDo you know any CAD system? If so, draw the solid straps and draw a surface for the webs at the midplane of each strap creating a 1 mm gap to the solid.
If you don't know any CAD system, then in Workbench, add a Static Structural analysis system, and double click on Geometry to open SpaceClaim where you can draw what I describe above. There are SpaceClaim tutorials on this site in the list on the right.
September 11, 2019 at 3:49 pm
MaximilianSauer28
SubscriberDoes it also work in DesignModeler because I never tried it in SpaceClaim?
September 11, 2019 at 8:54 pm
SubscriberYes, you can do the same in DesignModeler.
September 12, 2019 at 9:42 am
MaximilianSauer28
SubscriberSo I made a sketch of the two solid straps but what do you mean with "draw a surface for the webs at the midplane of each strap creating a 1 mm gap to the solid
This is what I made first. Do I have to extrude next, or do I just draw a line through the middle of the straps to get a surface for the webs?
Sorry I don't get it, I don't know all that well about CAD
September 13, 2019 at 12:16 am
SubscriberYes, you have to extrude the sketch to make a solid. You can extrude a line to make a surface.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2142
1355
1144
462
