Preprocessing
Preprocessing
Bending stress
    • Naief
      I am beginner in ANSYS, and I would like to find the bending stress in a solid body. In mechanical user`s guide states that to lunsh bending stress object I have to set output controls of "general miscellaneous" option to yes. In addition, the mesh methode must be a thin walled mesh. Could you please help me finding  these options.
    • peteroznewman
      Do you want bending stress or the stress due to bending?  You can get the latter without any special effort on a solid body.
    • Naief
      Actually I want to calculate the bending stress in a cantilever beam subjected to forces on its top surface.
    • peteroznewman
      If your cantilever beam has a uniform cross-section, and the forces on the top are uniform across the width, you can use Beam elements on a line body and get bending stress. That is the best way.
    • Naief
      Thanks alot.
    • Naief
      Actually,I used the Beam elements on line body. I still have the same issue by finding shear stress too. An error says:
      For this result, the scoped geometry(s) or named selection should have at least one sheet or a face on sheet or a solid with solid shell mesh.
      It is the same issue by finding bending stress on solid  body. Is it releated to my Output control setting. ?
    • peteroznewman
      Please show your results.
    • Naief
    • peteroznewman
      Are these Beam Elements?
      If so, insert a Beam Tool, and you will have Bending Stress in the folder.
    • Naief
      Peter, I would like to share the ANSYS project with you, so that you can have a look on it. (see attached file above).
      First ,Yes, these are Beam Elements. I inserted a beam tool and then I found the following (Maximum Bending stress, and minimum Bending stress). It is fine !!
      But, why it is not possible to find the Bending and shear stresses if I choose them from (Solution B6) ?
Viewing 9 reply threads
