November 21, 2018 at 4:13 am
Alexandre11
SubscriberHello everyone.
Can someone suggest the best meshing strategy for the attached geometry?
regards
November 21, 2018 at 4:19 am
Sandeep Medikonda
Ansys EmployeeI don't see any attachment. Please go over the video tutorials provided in the youtube channel.
There are also a lot of tutorials provided in the Help Manual.
November 21, 2018 at 4:30 am
Alexandre11
SubscriberThanks for your reply.
the geometry is attached here
https://drive.google.com/uc?id=1eT-I9OdrVliQp5Sv-EWrO4TTy5fUyND5&export=download
November 21, 2018 at 5:58 am
Keyur Kanade
Ansys EmployeePlease insert some images of the geometry. As ANSYS we are not able to download attachments.
You can also check following.
November 28, 2018 at 3:24 am
November 28, 2018 at 3:52 am
Keyur Kanade
Ansys EmployeeThis a simple geometry and you can create a hex mesh in it using sweep method.
Please have a look at following video for the same.
Please make sure that you create a single part in DM and then proceed to meshing so that the geometry will be decomposed with inner bodies automatically by sharetopology.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
