October 1, 2023 at 3:18 pm
shanyco
SubscriberHello,
I'm using the "grating s parameters" object with 'BFAST' settings (simulating different oblique angles) for a plane wave incidenting a periodic structure.
In many cases I'm getting this warning -
And the transmission data does not seem reasonale at all (it looks like a delta function with a peak of 10^6, sometimes 10^8...).
Can you help me understand this warning? How to overcome it?
thank you very much,
Shany
October 2, 2023 at 10:31 pm
Amrita Pati
Ansys EmployeeHi Shany,
Is there any chance you are using a polarization other than s or p? I believe the grating s parameters analysis group can only handle s and p-polarized sources. So, if the "polarization angle (degrees)" field in the plane wave source is anything other than 0 (p-polarized) and 90 (s-polarized) then the analysis group will most likely give you inaccurate results.
Amrita
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
