April 27, 2022 at 10:22 pm
Kyle
Ansys EmployeeThis is a question regarding the example: https://support.lumerical.com/hc/en-us/articles/360042322634-Biosensor-circuit
I am trying to reproduce this example, and I had the following questions and was wondering if anyone could help with this:
- Where is the source light physically located here? I see the wavelength used in the Eigensolver analysis box, but where is the physical location of the source?
- How do I change the source to be purely TE/TM mode light?
April 27, 2022 at 10:55 pmKyle
Ansys EmployeeA mode solver calculates the modes of a waveguide, so it doesn't have a light source. In this example we take the mode properties calculated from the FDE solver and apply them to waveguide models in INTERCONNECT. The "light source" in the INTERCONNECT simulation is the ONA, which measures the transmission through the circuit.
As mentioned above, the FDE solver doesn't have a light source. It will find both TE and TM modes, as long as you haven't applied any symmetry boundary conditions. To change the mode input by the ONA in INTERCONNECT, you can change the "orthogonal identifier". Note that you set which orthogonal identifier corresponds to which mode when exporting the results from the FDE solver, as mentioned in this example. You will have to make sure the elements in the circuit have the right data for the modes you're selecting.
Viewing 1 reply thread- The topic ‘Biosensor Application Gallery example’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
