March 10, 2021 at 1:01 am
Amal85
SubscriberHi nI would like to simulate amplifier on PCB in HFSS. May I know how I can represent BJT or diode in HFSS?. -
March 10, 2021 at 4:50 pm
Praneeth
Ansys EmployeenThank you for reaching to us. Please let us know what kind of analysis you would like to do to help us serve you better.nBest Regards,nn -
March 10, 2021 at 10:11 pm
Amal85
SubscriberI would like to to see the radiated power of antenna on a PCB. On the PCB, it will consists of other components such as amplifier circuit, matching circuit and antenna. The amplifier consists of BJT and other lump components. If lump component, we can use lumped RLC boundary . How about BJT?n -
March 11, 2021 at 2:27 pm
AndyJP
SubscriberHFSS is for passives (+ new feature of charged part. streams). Circuit design (former Nexxim) is a kind of Spice for circuits. Link these designs using circuit ports. You will probably need a license.n
- Maxwell, HFSS or Q3D?
- Error
2688
2138
1355
1140
462
