November 20, 2018 at 8:37 pm
November 20, 2018 at 10:26 pm
November 21, 2018 at 5:26 am
November 21, 2018 at 10:35 am
Bruss
Subscriberi did it but it does not change the black window
November 21, 2018 at 11:42 am
seeta gunti
Ansys EmployeeCan you close the FLUENT and reopen the fluent and select the workbench defaults.
November 21, 2018 at 7:13 pm
Bruss
SubscriberI tried but nothing changed
November 22, 2018 at 6:41 am
seeta gunti
Ansys EmployeeBetter check with graphics drivers. I guess you need to update the drivers.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2142
1355
1144
462
