Blank Solution Statistics
    • utkug
      Hello, for some reason whenever I complete a simulation on Mechanical 2019 R3, the solution statistics came out blank. I was wondering if someone else also experienced this?
      Utku
    • Aniket
      Is your analysis completely solved? (can you evaluate results?)
      have you saved your project before starting to solve it?
      right-click on the solution folder and open solver file directory, what files do you see there?
      -Aniket
    • utkug
      Hello Aniket,
      - My analysis was completely solved.
      -I haven't saved it before solving it and here is my solution folder. Also on the same project, I ran another analysis and I can see the solution statistics.
    • Aniket
      can you please check the solve file and open in a text editor? does it open there? also what is the extension of the file?
      Sometimes, in case of very large models, solve.out file is not shown when the file size goes beyond a limit, but that doesn't seem the case here at all, as the file sizes seem reasonable.
    • utkug
      I believe it was a writing problem related to Dropbox. It works fine now. Thank you so much for your help Aniket!
      Utku
Viewing 4 reply threads
