LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Blanks in cross sections using the section plane in LSPP
    • chayir
      When I observed the information of a cross-section using the section plane in LSPP, sometimes, some blank spots were observed. it seems that some elements at the selected cross-section are gone. I set the scale of displacement as zero.  What are the potential causes?  Thank you!
      Kind regards,
      Chayir
    • Ram Gopisetti
      Hi Chayir,
      can you check with the newer version of LSPP ?
      Cheers, Ram
    • chayir
      Hi Ram,
         Thank you for your suggestion! I used the lspp4.11. it is the latest version.  when I move the section plane 0.1mm, no blanks are at the cross-section.
      Best regards,
      Chayir
