Photonics
Photonics
Blazed grating optimization in Lumerical
    • Dmytro Fedin
      Hello All,
      Ansys Optics Support team has presented the showcase example (https://optics.ansys.com/hc/en-us/articles/360041613174-Blazed-grating) which describes the blazed diffraction grating in Lumerical. The example is very helpful but I got some questions:
      - How can I optimize blazed grating to achieve high diffraction efficiency?
      - Could I include to the optimization function the variable parameters like blazed angle, height of groove profile or line density?
      I found only one example using a parametric sweep (
      ) but I believe that Lumerical has a more powerful tool to provide a complicated optimization process.
      I would be grateful for any help!
    • Guilin Sun
      Lumerical has a built-in optimization based on particle-swarm method, and if you have API license you can use either Matlab or Python optimization.
      In this example https://optics.ansys.com/hc/en-us/articles/360041613174-Blazed-grating the blaze grating is script with theta, and period. You can modify it, or use your own math to modify the script to create the desired grating. Please try.
