September 17, 2022 at 4:44 am
junaed.buet
SubscriberHello. I have designed a 2D FE model of BLDC motor in ansys maxwell. I was hoping to derive efficiency and torque speed curve (like from figure1) from the simulation either directly or processing the data received from simulation.However the BLDC motor the winding current is rectangular current and I have used maxwell circuit to design an external circuit and excite the windings with that external circuit (Like Figure 2). I have sweep the speed of the motor and received the torque vs speed curve and efficiency vs speed curve (Figure 3). To get the curves like figure 1 , I need to control the current to limit it to the desired peak current. How can I excite the windings with rectangular current to get the current profiles like that of figure 4. The figure 1 profiles have been received via exciting the windings with sinusoidal current equation. How can I write rectangular current equation in my case? Or is there any other way in this regard? Thanks in advance.
FIGURE 1
FIGURE 2
FIGURE 3
FIGURE 4
September 19, 2022 at 8:39 am
Navya C
Ansys EmployeeHi junaed.buet,
You can write a pwl function for each phase current to define the square wave current waveform.
Refer the below discussion to understand how to implement a pwl function.
Regards
Navya
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
