Body Force UDF
    • RCamp35
      Hi everyone,
      I am trying to hook a compiled UDF for caculating body forces on particles. However, when I am going to hook the UDF it keeps warning that the code is not compiled for parrell solver. Is this most likely due to something within my code or something else? My code is as follows:
       Thank you!
      RCamp
    • Keyur Kanade
      as ANSYS employee, we dont debug udfs for customers. please go through customization manual. it also has an example of the same.
    • Keyur Kanade
      for accessing help, please check following thread.
      https://studentcommunity.ansys.com/thread/how-to-access-the-ansys-online-help/
    • RCamp35
      Okay I have figured out that the error is in my subscripts it says that "subscript requires array or pointer type" however, I thought that tp was the pointer. Can anyone help push me in the right direction now?
      I don't think you've assigned a vector for your force: if you look at the example and your code you need the [0] and [1] etc where these define x & y directions, similarly [2] is z.
      No idea if there's anything else that's causing a problem: but that'll give you something to do over Christmas!
    • RCamp35
      It was the O it should of been a zero in the VELO.
      Thank you guys!!
Viewing 5 reply threads
