Discovery Import
Discovery Import
Body intersection does not work
    • sandor_toaso
      Hi
      Why  does not the body intersection work?
      It is a clear geometry. Please advice
      working file is attached 2021R1
      please do not publish the working file
      thanks for your advice in advance
      regards,
      Sandor
    • Naresh Patre
      Hello SandorToaso
      If you right click on CFD body and select "Check Geometry", it will report some errors associated with this body. The interference operation is most likely failing due to these errors. Please fix these errors and then try again.
    • sandor_toaso
      Thank you. Indeed however impossible to fix the complained geometry. I tried all of the repair options and nothing has found issue with it. I cannot even select the problematic large surface to delete or remove it. Please advise.
      thanks and regards sandor
    • Naresh Patre
      Hello SandorToaso
      I have sent you a video through email showing the steps to resolve the interference issue.
    • sandor_toaso
      Hi
      where did you send the email? unfortunately I have not got it yet.
    • Naresh Patre
      Hello SandorToaso
      I just noticed that the email which I sent earlier today got bounced back. I have sent the email again. Please let me know if you didn't receive it.
    • sandor_toaso
      Thank you I got it.
      Highlighting the defective geometry is possible by clicking on the error message in geometry check window. Once the defective entity is selected use RMB detach geometry and replace it with missing faces option. Wavy close proximity is not allowed in case of Boolean operation hence simple increase the gap and the intersection will be allowed.
      Thank you
Viewing 6 reply threads
