June 26, 2022 at 2:54 pm
June 29, 2022 at 12:32 pm
Ashish Khemka
Ansys EmployeeHi Luis,
Are you expecting the parts to interpenetrate? Can you try defining the contact region?
Ashish Khemka
June 29, 2022 at 2:06 pm
luis.serra5
SubscriberHi Ashish!
No, that's not what I want. I want to see part's behavior after a car impact and interpenetration is not expected. I tried to define some contact pairs but this problem is still happening. I am using shell elements in the mesh.
Thank you for your answer. Regards,
Luís
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3720
2570
1777
1236
594
