May 27, 2022 at 12:20 am
AbdelrahmanGomaa
SubscriberHello Everyone
I'm working on cooling of a hot plate using water jet numerically. I'm interested in plotting the boiling curve X-axis = delta T ( Tsurface-Tsaturated) / Y-axis =Heat flux. I tried doing it but I didn't get any results. I just want to make sure if I'm using the right formulas and parameters or not.
What i know:
T surface is the temperature of the top surface of the plate .
T saturated is 100 C
what about the Heat flux I know fluent calculates it but since the problem is 2d I get undefined value.
I hope I can get a response.
Thank you in advance.
May 27, 2022 at 10:37 am
Nikhil Narale
Ansys EmployeeHello
What do you mean by undefined value?
For 2d, fluent takes the unit depth by default for calculations. However, you can check/modify the depth value from the 'Reference Values' tab. Even if the problem is 2d, you should get a value for the heat flux.
Nikhil
May 27, 2022 at 3:43 pm
AbdelrahmanGomaa
SubscriberIs this related to the post processing. Because I'm interested in getting the flux values with respect to time?
May 30, 2022 at 9:49 am
Nikhil Narale
Ansys EmployeeYes, that's correct. You can ignore it while solving as it has no effect on the solution.
3744
2573
1793
1236
594
