February 9, 2021 at 12:20 pm
happykiran
SubscriberI have an M5 bolt with a torque of 36lbf-in can someone give appropriate formula to calculate the Pretension load.nAnd also kindly explain more on the bolt load definition methods of 1. combined 2. adjustment 3. openn -
February 10, 2021 at 1:58 pm
Aniket
Ansys EmployeePlease check online for some converters and/or theory references that can give you axial load in the bolts for a given torque. Ansys needs axial force/adjustment for bolt pretension application, and cant use the torque for bolt pretensioning.nI hope you might have looked at https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v211/en/wb_sim/ds_Pretension.html and previous questions like Determination of preload in bolt pretension ? Ansys Learning Forumn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
3311
2471
