Tagged: bolts, force-reaction, joints, modal, response-spectrum, structures
August 18, 2022 at 2:41 pm
AR
SubscriberHello,
I perfomed a Response Spectrum Analysis in order to simulate an earthquake event (Static structural->Modal->Response spectrum). I want to obtain the force reactions on bolts. In this moments, my bolts are modelized as joints. I know that in Static structural is possible to obtain the reactions on joint but in Response Spectrum i don't know how to do this.
Is there any way to obtain the reacions on joints, beams or faces/edges in Response Spectrum? I use Ansys 2021 R1
Best Regards,
One way is to use APDL commands to get these values. You will need to use the file.mcom (mode combination file) that is available ( Solution> right mouse click > Open solver files directory). This file may also be called displacement.mcom.
You also should save the database (file.db) using Analysis settings> Analysis data management > Save MAPDL db file= YES.
In Post1 you can use ETABLE command to get beam results. Starting in 2022R1 I think you can also get joint results with ETABLE.
Then you can use the below commands:
resume
/post1
/inp,file,mcom
etable ..... ! use ETABLE for beams/joints
pretable ! print results
Hi Chandra,
Thank you for your post.
I tried to what you explained to me, but I couldn't obtain nothing. I don't have much idea about scripting in APDL commands. I write the next lines (and some others ways that I found in internet) but I wasn't able to obtain results.
I atach a WBPZ file with the model. I will really apreciate if you could see it and help me with this issue. Link to OneDrive -> https://1drv.ms/u/s!Am8sCtJMJkfCctFl27XjNXIXjio?e=ks5hqb
2146
1357
1150
462
