August 28, 2019 at 3:42 am
simonfur1
SubscriberDear community,
Ive been hitting the wall lately while performing something so simple as applying contact between to interfacing volume meshes (that simulate a CF-layer and a thin piezo electrical layer).
It will not bond. Running a modal analysis make the parts split in all directions.
I try to avoid using nummrg as I will make the piezo layer much thinner, and apply way more elements to it, making the element amount very different from the top layer to the bottom one. ( Ideal situation for using contact elements)
Please see my attached code. Do anyone have any good ideas? -
August 28, 2019 at 10:12 am
SubscriberI have copied your code into this post because ANSYS staff are not permitted to open attachments.
/CLEAR
/PREP7
/UIS,MSGPOP,3
/title, Harmonic analysis of a carbon-fibre layered beam with ZnO
!Element Types !
!Composite layer element type
ET,1,SOLID185,,,1 !Remember to give same thickness in secdata as in the given volume
!Glass layer element type
ET,2,SOLID185,,,1 !Remember to give same thickness in secdata as in the given volume
!Piezoelectric Element
ET,3,solid226,1001
!Contact element:
ET,4,CONTA174
!Resistor Element
ET,5,CIRCU94,0
!Target element
ET,6,TARGE170
! ELement division:
!attribute for volume (Warning, picked lines cant be one same height)!
*set,plmesh,10 ! mesh for plate=number of segments
*set,pzmesh,20 ! mesh for pzt=number of segments. Set to the same to avoid additional contact meshing (difference is minimal)
*set,meshthc,1 !no of element through thickness of piezo
tccf=0.000120 ! cf layer thickness
tcglass=0.00012 ! cf layer thickness
tZnO=1e-4
BeamW = 0.032
BeamL = 0.239
CFL1=0.119
GFL=0.151
CFL2=0.154
! Top electrode size:
Ell=0.1
Elw=0.02
! Offset from clamped edge:
GOff=0.015
CF2off=0.085
!Piezoelectrical lyers offset:
OffsetX1=0
OffsetX2=0.120
!Material Properties !
!CF Material Properties
MP,DENS,1,1100 ! From measurment of acutal beam
MP,EX,1,45.01e9 !Elastic modulus, x-direction
MP,EY,1,45.01e9 !Elastic modulus, y-direction
MP,EZ,1,20e9 !Elastic modulus, z-direction
MP,PRXY,1,0.35 !Major poisson's ratio, x-y plane
MP,PRYZ,1,0.2 !Major poisson's ratio, y-z plane
MP,PRXZ,1,0.35 !Major poisson's ratio, x-z plane
MP,GXY,1,2.892e9 !Shear modulus, x-y plane
MP,GYZ,1,2e9 !Shear modulus, y-z plane
MP,GXZ,1,2e9 !Shear modulus, x-z plane
!Glass Material Properties
MP,DENS,2,1500 ! From measurment of acutal beam
MP,EX,2,22.99e9 !Elastic modulus, x-direction
MP,EY,2,22.99e9 !Elastic modulus, y-direction
MP,EZ,2,5e9 !Elastic modulus, z-direction
MP,PRXY,2,0.3 !Major poisson's ratio, x-y plane
MP,PRYZ,2,0.2 !Major poisson's ratio, y-z plane
MP,PRXZ,2,0.3 !Major poisson's ratio, x-z plane
MP,GXY,2,2.2627e9 !Shear modulus, x-y plane
MP,GYZ,2,1e9 !Shear modulus, y-z plane
MP,GXZ,2,1e9 !Shear modulus, x-z plane
!! Piezo material properties
MP,DENS,3,1160 !from resin epoxy. Should be modified when real speciments are prepared
! Anisotropic properties given as resin epoxy, since crystals do hold very little load individually (approximation):
MP,EX,3,3780e6 !3780e6, this is resin epoxy. Use however PZT for comparison
MP,PRXY,3,0.35
MP,GXY,3,1400e6 !From resin epoxy
! See material properties and lirarature overview to see where this is from
MP,PERx,3,877.6
MP,PERy,3,877.6
MP,PERZ,3,1006.3
TB,PIEZ,3,,,0
TBMODIF,1,1 TBMODIF,1,2 TBMODIF,1,3,-0.62 !e13
TBMODIF,2,1 TBMODIF,2,2 TBMODIF,2,3, !e23
TBMODIF,3,1 TBMODIF,3,2 TBMODIF,3,3,0.96 !e33
TBMODIF,4,1 TBMODIF,4,2, !e42
TBMODIF,4,3 TBMODIF,5,1,-0.37 !e51
TBMODIF,5,2 TBMODIF,5,3 TBMODIF,6,1 TBMODIF,6,2 TBMODIF,6,3
!Geometry Dimensions !
!Composite layer 1
materid=1 !material id
ang1=0 !angel of layer in degrees
SECTYPE,1,shell,,layer1 !define which element type
SECDATA,tccf,materid,ang1 !define thikncess and angle
!Glass layer
materid=2 !material id
ang2=0 !angel of layer in degrees
SECTYPE,2,shell,,layer2 !define which element type
SECDATA,tcglass,materid,ang2 !define thikncess and angle
!Reserved Nodes for Circuit !
!circuit dimension
cirdim = 0.02
n,1,-4*cirdim,0,3*cirdim
n,2,-4*cirdim,0,cirdim
n,3,BeamL+4*cirdim,0,3*cirdim
n,4,BeamL+4*cirdim,0,cirdim
!FEM Domain Geometries !
!Create Beam, Epoxy and Piezoelement nr 1 (start on top and go downward)
BLOCK,0,CFL1,-BeamW/2.0,BeamW/2.0,0,tccf ! CF layer 1
BLOCK,0,CFL1,-BeamW/2.0,BeamW/2.0,0,-tZnO !Piezo Layer 1
!Mesh !
! Corner line meshing of all SOLID185 elements (cant be divided in thickness)
LSEL,S,LINE,,9,12,1 !SELECT CORNER LINES OF composite LAYER 1
LESIZE,ALL,,,1 !# OF ELEMENT DIVISION
! Composites layers length/width meshing:
LSEL,S,LINE,,1,3,2 !SELECT SHORT LINES OF beam
LSEL,A,LINE,,6,8,2 !SELECT SHORT LINES OF beam
LESIZE,ALL,,,plmesh !# OF ELEMENT DIVISION
LSEL,S,LINE,,2,4,2 !SELECT LONG LINES OF beam
LSEL,A,LINE,,5,7,2 !SELECT LONG LINES OF beam
LESIZE,ALL,,,(plmesh*(CFL1/BeamW)) !# OF ELEMENT DIVISION
!Piezoelectrical layer meshing thickness:
LSEL,S,LINE,,21,24,1 !SELECT CORNER LINES OF composite LAYER 1
LESIZE,all,,,meshthc
LSEL,all
!Short side of piezo:
LSEL,S,LINE,,13,15,2 !SELECT SHORT LINES OF beam
LESIZE,all,,,pzmesh
!Long side of piezo:
LSEL,S,LINE,,14,16,2 !SELECT LONG LINES OF beam
LESIZE,ALL,,,(pzmesh*(CFL1/BeamW)) !# OF ELEMENT DIVISION
! Assign material to volumes
VSEL,S,VOLU,,1 !SELECT layer 1
VATT,1,,1 !ASSIGN ELEMENT ATTRIBUTES
VSEL,S,VOLU,,2 !SELECT PIEZO PATCH 1
VATT,3,,3 !ASSIGN ELEMENT ATTRIBUTES
VSEL,ALL
!VMESH,1,8,1
vsweep,all
*get,Epz,elem,,count ! Get all the number of solid elements
!Bond together layers with the contact and target element !
! Define bonded contact, (from Principles of Simulating Contact Between Parts using ANSYS)
KEYOPT,4,2,1
KEYOPT,4,5,1
KEYOPT,4,6,0
KEYOPT,4,7,0
KEYOPT,4,8,2
KEYOPT,4,9,1
KEYOPT,4,11,0
KEYOPT,4,12,5 ! Keyopt 12 set to 5 is a bonded always condition
!Target surface:
ASEL,S,AREA,,1 ! Select area at the top and bottom of the patch
TYPE,6 ! Selectn element type
real,3 ! Sets the element real constant set attribute pointer
NSLA,S,1 ! Select those nodes associated with the selected areas
ESLN,S,0 ! Select those elements attached to the selected nodes
ESURF,ALL ! Generate elements overlaid on the free faces of selected nodes
ASEL,S,AREA,,8
type,4
real,3
NSLA,S,1
ESLN,S,0
ESURF,ALL
!Check normals:
ESEL,S,TYPE,,4
ESEL,A,TYPE,,6
/PSYMB,ESYS,1
EPLOT
! Reverse Contact Normal (maybe not necessary)
ESEL,NONE
ESEL,A,TYPE,,4
ESURF,,REVERSE
eplot
ESEL,S,TYPE,,4
ESEL,A,TYPE,,6
eplot
/PSYMB,ESYS,0
! CONTACT PAIR CREATION - END
Open-Circuit Modal Analysis
/SOLU
antyp,modal
nmodes = 10
MODOPT,LANB,nmodes,0,500
MXPAND,nmodes !Specifies the number of modes to expand and write for a modal or buckling analysis.
!Load & Boundary Conditions !
!Structural BCs
nsel,s,loc,x,0
d,all,ux,0
d,all,uy,0
d,all,uz,0
alls
solve
finish
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1349
1118
461
