March 8, 2021 at 9:59 am
shadowfax7
SubscriberI have an inner geometry embedded in my outer geometry (see small tube in larger geometry) and I want to make sure I have 2 separate bodies, the outer without the inner, and the inner. When I use Boolean Subtract in Design Modeler, my geometry seems to break apart? I tried fault detection but the model does not seem to contain any faults.
Any tips?
March 8, 2021 at 10:34 amKeyur Kanade
Ansys EmployeeYou can create a plane. Then slice geometry with that plane and separate the region of interest. Then you can subtract the geometry only for that particular body. nAlso you can try SpaceCalim. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2630
2106
1335
1110
461
