Preprocessing
Preprocessing
Boolean dependent named selection (Feature Dependencies)
    • niranjanmk16
      Dear Ansys Community,
      I want to simulate the flow around a rotor and want to create a fluid domain as attached in the picture. I am unable to perform the following named selection which has feature dependencies on the boolean operations. Please let me how do I manually select these faces of the inner domain or is there any particular option for named selection depending on boolean operations?
      Thanks in advance.
    • RK
      Is there a shared topology between them?
    • niranjanmk16
      Dear RK There is no shared topology between the bodies. It seems to be just a normal named selection depending on the boolean operation.
