June 24, 2023 at 12:01 am
June 24, 2023 at 2:06 pm
Raihan Lutfianto
SubscriberHi Arba, please refer to this ANSYS FLUENT – Operation would result in non manifold bodies
Non-manifold means you're creating an impossible geometry, typically with a surface of zero area. Also, try to extract fluid volume via SpaceClaim.-
July 10, 2023 at 2:45 pm
Leonard Collum
Subscriber"Hi Arba, please refer to this ANSYS FLUENT–Operation would result in time shooter 2 manifold bodies
Non-manifold means you're creating an impossible geometry, typically with a surface of zero area. Also, try to extract fluid volume via SpaceClaim."It turned out that my geometry was in the case of impossible geometry. So, It can't be a boolean. Thanks for your useful information.
June 25, 2023 at 2:34 am
Arba Agos Aditya Pranoto
SubscriberThank you for your answer Mr. Raihan, it was very helpful😁
- Features of the check case
- Room with Air-Conditioning Vents
- Error Floating Point Exception
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Heat transfer radiation through glass
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Viscous Models
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Torsion Stiffness
7592
4440
2953
1427
1322
