August 29, 2018 at 12:28 pm
monicaagabriela
SubscriberHello,
I want to follow this youtube tutorial:
The only issue is that I cannot find the Boolean feature in Ansys 19.0. Can someone help me? What should I do?
Kind regards,
Monica
August 29, 2018 at 12:32 pm
Keyur Kanade
Ansys EmployeeHi,
Its there under Create --> Boolean.
Can you please insert image of what you can see under Create option.
Keyur
August 29, 2018 at 12:36 pm
August 29, 2018 at 12:47 pm
August 29, 2018 at 1:05 pm
Keyur Kanade
Ansys EmployeeHi,
This is SpaceClaim.
In this, you can use Combine tool under Design tab.
Keyur
August 29, 2018 at 1:26 pm
monicaagabriela
SubscriberThank you! It opens automatically in SpaceClaim when I click on "Geometry" -> "Edit" in Workbench. Can I change it? I should mention that I am a beginner. Thank you so much!
August 29, 2018 at 1:37 pm
August 29, 2018 at 1:42 pm
August 29, 2018 at 1:45 pm
Keyur Kanade
Ansys EmployeeDM need not be installed separately. It should get installed with default installation. Can you please try reinstalling it.
Also you can continue operations in SpaceClaim instead of DM. SpaceClaim is also very user friendly. You will need to use only Combine tool for boolean operations. I would recommend you to go ahead with SpaceClaim. You would love it.
Keyur
August 30, 2018 at 12:27 am
tsiriaks
Ansys EmployeeHi Monica,
Are you using the Free ANSYS Student version or some paid academic/commercial license ?
I'm guessing that the latter would be the case here. It's likely that you have a licensing issue.
In this case, check if you have licenses for ANSYS Design Modeler.
You can try this command in CMD Prompt (change your installation path accordingly)
“C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_util” -checkout ANS_DM
Note: Copy the entire thing including quote ""
Please capture the screenshot of the output and put it in your post here.
Thank you,
Win
October 21, 2019 at 4:25 pm
sumankumar
Subscribersir I created airfoil with boundary but in meshing I am only getting airfoil! any solution
October 21, 2019 at 6:36 pm
Subscriber@sumankumar, please open a New Discussion.
November 25, 2020 at 6:20 am
firdausghani
SubscriberHello, I want to ask how do I Boolean whole parts of my modelnI want to model my uav modelnwhen I select, it only selects the wing and the tailn -
November 25, 2020 at 6:32 pm
Subscriberplease open a New Discussion.nWhen you do, please insert some images to show the problem you are having.nSay what version of ANSYS you are using, say what CAD system created the UAV geometry, say what file format you exported from your CAD system, say which ANSYS app you are using: SpaceClaim or DesignModeler.n -
December 22, 2020 at 1:28 pm
Jiri
SubscriberHello.nDecember 22,2020nThis is addressed to monicagabriela or anyone else, who can answer my question.nI am interested t know, how did you managed to upload video to the page> nI tried to upload mp4 video ( mp4 being the mot common format for MS Widows)...but the system rejected it with message it doesn't conform to the extensions allowed and then list of extensions was shown, which were (I believe) only a picture formats...nn
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
