April 24, 2023 at 9:23 am
Vasco Godinho
SubscriberHello everyone,
I am studying the flow around a helmet and I am trying to perform a boolean subtract operation in ANSYS. However, I am encountering the error message "". I have seen in other posts that the helmet cannot be hollow, which is the case for my geometry obtained from GrabCAD. I have tried filling the inside of the helmet using CAD software, but due to the complexity of the geometry, I was not successful.
Does anyone have any suggestions on how to proceed with this?
April 24, 2023 at 10:53 am
Ansys EmployeeWhat do you want to do with the helmet geometry?
April 24, 2023 at 11:06 am
Vasco Godinho
SubscriberI created an enclosure and now I want to define the fluid zone.
April 24, 2023 at 11:13 am
Ansys EmployeeOK. You can either clean up the outer casing of the helmet & then mesh. The non-manifold issue is down to surfaces not quite touching, or rather touching with a zero area contact.
Or, have a look at the Fault Tolerant Meshing option in Fluent Meshing.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2471
