March 9, 2021 at 11:59 pm
hansenli
SubscriberHi,nTo boost the computation, we purchased a new workstation with 26 cores * 2 cpu = 52 cores in total. However, when we tested it using a small project, the new workstation took even more time than previous workstation. I don't understand why such thing happens. How should we set up the software so that we can maximize the speed using this dual processor workstation?.Many thanks,nWilfredn -
March 10, 2021 at 1:21 am
SubscriberHi Wilfred nWhat was the clock speed of the old workstation? What is the clock speed of the new workstation?nIf the old workstation had a 3.6 GHz clock and the new workstation has a 1.8 GHz clock, single thread calculations will take twice as long.nThere is a linear relationship between clock speed and solution time.nHowever, the relationship between cores and solution time is very nonlinear and highly dependent on the type of solver and the type of model.nIn general, doubling the number of cores will not half the solution time. Doubling again will have an even smaller reduction.nSmall models may not benefit very much from high core counts. Larger models may be required to see the effect.nYou also need to have the HPC licenses to use many cores. Without an HPC license, the solver will use 4 cores and no more.n -
March 11, 2021 at 5:05 am
hansenli
SubscriberThank you for your help! Our old workstation has 8 cores and 3.7 GHz base speed. Our new workstation has 52 cores and 2.1GHz. If I am understanding correctly, the calculation time will be shorter if we use it to simulate a large model (with HPC license). Is that correct?n
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
