Boundary condition at the corner of square cavity
    • Aminaa
      i try to simulate a natural convection in square cavity by using hyperbolic mesh on ICEM.
      the lenght cavity is 0.3m . i run the programme it works.
      • when i opened the file that contain the export data of my configuration, i am surprised !!! the last value of x coordinate wa 0.3000000119 ?? while i imposed L=0.3 m.
    • DrAmine
      Round off errors might happen. How did you do the export sbd what do you mean with the hyperbolic mesh? What dies ICEM CFD tell sbout mesh extents?
    • Aminaa
      thanks Dr Amine for answing.
      for exporting solution data : i clicked on file ->export->solution data -> file type : ascii ->location: noeuds->surfaces: fluid-> quantities
      ii used yperbolic mesh law on ICEM :hyperbolic distribution of the nodes along the edge (i attached a picture for expression and you can see on the ICEM-HELP-MANUAL P481
    • DrAmine
      What does the software report about the mesh extents?
    • Aminaa
      what do you mean by 'mesh extents'? the passage from ICEM to ANSYS ???
      What does ICEM CFD report for the domain extents? Did you open Fluent in double precision?
Viewing 5 reply threads
