We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
Topics related to Fluent, CFX, Turbogrid and more.
Boundary Condition for Natural Convection
    • cha10
      I want to simulate air flow around heated/cooled body due to the natural convection. I am not really sure how to put the boundary conditions.
      Here are what I think
      1. Assign the temperature to the body, 2. no heat flux to the ground, 3. Pressure-inlet at the top boundary, pressure-outlet at the side.
      Are these fair boundary conditions?
      Thank you!
    • Raef.Kobeissi
      Yes but you need to make sure that the ideal gas is selected and also the Boussinesq Parameter is set up. Please see figures below:
    • gishnutr
      Hi, Raef
             I your comment above, you mentioned to use ideal gas as material. I have three doubts in this.
        1. The incompressible-ideal gas also have same values in the given tab. Is it just a incompressible fluid/ flow version of ideal gas model or is there any other explanation for using these two?
      2. If Boussinesq parameter is set up in Operating conditions tab, then what is the use of the Boussinesq term in Density model selection under Edit Material  tab?
      3. In Operating conditions tab the operating density id given as "0". By default the value is 1.225. Why is it changed to 0?
      Thank you.
    • Karthik Remella
      Administrator
      To answer your questions:
      1. An incompressible-ideal gas law is used to estimate the density of an INCOMPRESSIBLE fluid using the ideal gas law (check out section 7.3.6., Fluent User's Guide).
      2. The density drop down in the material property panel allows you to choose the Boussinesq approximation model and it uses a constant value of density by writing the buoyancy term as a function of operating temperature (section 12.2.4.2, Fluent User's Guide). You will also have to specify thermal expansion coefficient (beta).
      3. Operating density is non-zero because it appears in the body-force term of the momentum equation. When Boussinesq approximation is used, this value becomes irrelevant and therefore need not be specified. Care should be taken while specifying the operating density (section 12.2.4.5, Fluent User's Guide).
      I hope this helps.
      Best Regards,
      Karthik
    • NicholasS
      How about the other settings?
      Should it be Pressure or Density based?
      What kind of solution methods?
      If I activate the 'Specified Operating Density' I always obtain an unrealistic velocity field even when the 'warm' surface is at the same temperature as its surroundings. When I turned it off, at least  in the case of zero difference in temperatures, the velocities drop realistically to ~0.
      Forum Moderator
      If the system is sealed you need ideal gas. Operating density should be the mean value in the domain (near enough) in that case. I assume you did turn on gravity?
    • tungseng99
      Hi guys,
      May I ask do I need to specify the operating density if I'm using the incompressible ideal gas?
      Thanks in advance :)
      Forum Moderator
      Do you have openings?
Viewing 7 reply threads
  • The topic ‘Boundary Condition for Natural Convection’ is closed to new replies.
