Preprocessing
Preprocessing
Boundary Condition transfer in sub-modeling
    • Rajdeep_11
      I am trying to do sub modeling in a small cube-type block embedded at the center of a bigger block. The faces of the smaller cube have a number of surfaces (divided into triangles). Is it possible to transfer the boundary conditions from one surface of the bigger block to which it is attached to the multiple surfaces of the smaller block? Does Ansys take it by default, i.e. if I deliver a load of 100N from one face of the bigger block into 400 small faces of the smaller block, will it distribute the load evenly? n
    • 1shan
      Hello Rajdeep.nIt is indeed possible to transfer boundary conditions to a submodel without worrying about the distribution. Please check out this video
      and let us know if it resolves your issue. nRegards.n
