August 8, 2019 at 1:43 pm
ozankekul
SubscriberHello;
Im modelling a combustion case. i have calculated air fuel ratio by hand and i have found air mass flow rate 0,003268326 kg/s and fuel mass flow rate 0,000537634 kg/s. moreover, i have four air injector with dimension of 70 mm and i have defined one air inlet for all air injectors. moreover, i have six fuel injector with dimension of 42 mm and i have defined one fuel inlet for all injector. When i defined boundary conditions , should i divide total air mass flow rate to four and total fuel mass flow rate to six ? and what should i set hydraulic diameter for both air and fuel inlets.
August 8, 2019 at 2:15 pm
Ansys EmployeeYou set the flow based on the labelled boundary: in this case you have one setting for all 6 surfaces so use the total mass. Turbulence conditions are based on the size of the openings and not the total area if there are several.
Set the model up, run a few iterations and then use the report tools to convince yourself what Fluent is doing.
August 8, 2019 at 3:12 pm
ozankekul
Subscriberthanks for your support.
Regards.
2656
2120
1349
1118
461
