Boundary conditions for multiphae mixture problem
    • yelyaa
      I'm trying to simulate the effects of a nitrogen spill in a room, considering it has four outlets with specific mass flow rates, a pressure inlet and a nitrogen mass flow inlet.
      I cannot impose a mass flow rate at the outlets as the model does not allow it, neither use the outflow bc with massflow rate weights as I get a warning because I'm using compressible model (Reidlich Kwong) for the nitrogen.
      I have tried the species model but it takes ages compared to the mixture model
      Does anybody knows how if I can workaround this ?
      Many thanks
      What are you trying to model? Multiphase will need a phase interaction assuming the release is a liquid and it flashes, so will be very transient.
    • yelyaa
      Hello
      I'm trying to model a transient case for a Nitrogen spill in a room with ventilations. Two phases are present it's the air and the nitrogen. Over 37 min I want to see the effect of the ventilations (4 mass flow outlets) on the accident, represented by the nitrogen mass flow inlet on the floor.
      Does the nitrogen evaporate? Why do you need a fixed mass out?
    • yelyaa
      Yes, the nitrogen evaporate and I need a fixed mass flux out
      Try 2019R3, we've been doing a lot of work on multiphase over the last few releases.
Viewing 5 reply threads
