Boundary conditions mess up when changing geometric parameters in ANSYS WB. Help
    • ArisvHouten
      Hello all, here you the model that on which I'm doing a parametric study on. More specifically, on the thickness and the width of the top body and how they affect the max stress and stiffness of this so called spacer. Encircled in red the two bodies are bonded and encircled in yellow the bodies are frictionally bonded. The bottom part is connected to the ground and in yellow a prescribed displacement in z, and x and y are free. This rather simple model is solved correctly.
    • peteroznewman
      nThat is very strange. Please create a Project Archive .wbpz file, put that in a .zip file and attach that to your reply. Put a in your reply so I will be notified when you have put that up.n
