September 16, 2022 at 12:10 pm
alifian.timur
SubscriberHi, i'm having a problem regarding the Brake Pad Analysis Simulation. when i tried to run the analysis, the solid / brake disc are not rotating within the axis, and result in the sliding of the brake disc, as shown in the image below.
also i found these errors when i finished the simulation :
any help would be much appreciated
September 19, 2022 at 8:34 am
Shakthivel.T.S.
SubscriberHi,
Please can you share the screenshot of your remote displacement (this B.C. applies rotation) details window.
Also, please can you share your PC's RAM capacity.Best Regards,
Shakthivel.T.S.
September 19, 2022 at 1:27 pm
September 20, 2022 at 4:08 am
Shakthivel.T.S.
SubscriberHi Alifian Timur,
Please can you upload the model to the below zoho workdrive, to check the set-up:
Link:
https://workdrive.zohoexternal.com/external/894c127788776dc7aea08b222e65fc6b74d1d93e5670ac94b4a68a44fd2bbe59
September 20, 2022 at 11:42 am
alifian.timur
SubscriberHi Mr. Shakthivel.T.S.
I already uploaded the model file to the zoho workdrive link you provided.
Thank you.
- can’t login to cloud acccess using the same email on the independent campus web
- Selamat Datang
- Rosette Gauge Purpose
- Web Course Ansys
- Brake Pad Analysis Simulation Problem
- Cell Phone Drop Test Simulation Problem
- lumbar motions simulations problem- in solid mechanic
- Meshing Problem in Helicopter Pitch Arm
- Could anyone have solution to fix it? Thanks
- Lumbar Motion Simulation – Coding part
2524
2066
1283
1096
459
