Breakage and Coalescence rate
    • dhirajlote
      I am using Fluent 17.2 for the modeling of Gas-Liquid two phase flow with population balance modeling. In fluent 17.2, the existing models are. Luo, Lehr, Laakkonen, Ghadiri, Freemolecular and Turbulent. I have performed simulations with these models. is it possible to plot the breakage and coalescence rates itself in the fluent with these in-build model?.
      If you have a look in the manual it says what's available: since it's a function of birth/death rates you may need to write some expressions.
      We're currently using 2019R2: R17.2 is 3 years old now and we've put a lot of focus on multiphase in recent versions.
    • DrAmine
      You definetly need to rewrite the expressions. There is no supported workflow to access these rates.
    • dhirajlote
      Ok, I got it. Thank you.
    • DrAmine
      Please mark this as "is Solved"
Viewing 4 reply threads
