Preprocessing
Preprocessing
Breaking pattern relationship in spaceclaim
    • Govindan Nagappan
      To unpattern, you can drag and drop the component out of the pattern and it can then be edited independently as a component. Or Copy and paste the bodies will always make the bodies independentnThere is another right click option called make independent that is available after selecting bodies. This option only removes the instancing. It does not do an unpattern. So if you edit one component, you will see other components also affected by this because the pattern relationship is still therenn
    • Keyur Kanade
      Thanks Govindan!n
