Materials
Materials
Topics relate to Granta Design and more
Brinell’s Hardness test- Contact problem
    • Kariuki Karanja
      I am using the Hertz contact to define the contact between the indenter and the sample. I have follwed this video https://youtube.com/playlist?list=PLtt6-ZgUFmMKfcjKvN4Uoc7Z6CP4q8OAU&si=wEcjyGVTDq13Esbc . After running the simulation the indentation caused by the spherical ball is not taking the shape of the sphere. I have used a stiffnes factor of 1, formulation is augmented langrage and the contact friction is zero. The CONTACT element is the specimen and the TARGET is the indenter.
      My queries are, why is the indentation not speherical, the indentatio appears to be too small and the hardness number calculated is not corresponding to the theoretical value.
      Finally how do i calculate the tagent modulus for bilinear isotropic hardening.Why is contact depth not increasing with time?
    • Ashish Kumar
      Forum Moderator
      Can you try refining the mesh and then rerun the model? Also, please the snapshots of the contact results. The tangent modulus is material input and needs to be provided by the user.
      Ashish Kumar
    • David Mercier
      Hi, Hertz model is to define pure elastic contact. In your case, you want to extract hardness value from the indentation test and expect to have a residual imprint (corresponding to a plastic deformation). By curiosity, have you define plastic properties for the indented material  for example (at least simple bilinear work hardening law)? Then, is the applied load big enough to deform plastically the tested material? Is the indenter well defined as a rigid body?
      • Kariuki Karanja
        Yes I used bilinear isotropic plasticity for the material sample. The Force applied is 500kgf which is 4905N. The force is applied for 10seconds.
