November 5, 2018 at 7:45 pm
anamena
SubscriberHello,
Hello, I’m running a simulation of a 2L reactor. The domain is set up as multiphase (Eurelian), WATER and AIR. WATER is phase one and AIR is phase two and a 2k-epsilon ( disperse) model
My geometry has a 7 holes sparger at the bottom with a 1 mm diameter and a disperse velocity of 0.606 m/s.
The boundary conditions:
Top_tank is degassing, impeller and tank are walls, inlet (7 holes) are inlet with volume fraction 1.
I try to implement different bubble size with this set-up but is not working. I would like to now if there is another model that I have to include
I hope someone can guide me, I thank in advance anyone that will be so kind to provide some information
November 5, 2018 at 8:07 pm
DrAmine
Ansys EmployeeYou can think about using the Interfacial Area Concentration Model or one of Population Balance Approaches to model a dynamic PSD
November 7, 2018 at 8:06 pm
anamena
SubscriberThank you for the suggestion. Do you know if there are specific UDFs for the Population Balance model in order to setup different bubble diameter?
November 7, 2018 at 9:11 pm
DrAmine
Ansys EmployeeThe idea of population balance methods is that you do not require to set the diameter but to prescribe classes or moments to calculate a dynamic psd/diameter
November 13, 2018 at 12:15 am
anamena
SubscriberThank you for your help
2534
2066
1285
1104
459
