November 17, 2018 at 6:51 pm
Mary
Subscriberi am doing a egien value buckling analysis
bt i got a erorr
1-SUBSPACE solver failure. The assembled stress stiffness matrix contains all zeroes. No load factor solution is possible. what i do
November 17, 2018 at 6:55 pm
Mary
Subscriberand also i have a doubt
my ansys is 16.2
An eigenvalue buckling analysis was first performed to determine the lowest buckling mode, which could be used as the shape of the initial imperfection in
the following nonlinear FE analysis
so how can i do?
anyone knows about it?
November 18, 2018 at 1:58 am
Sandeep Medikonda
Ansys EmployeePlease use, inline images and explain your problem in detail. Like, how are you setting this up? Loading etc.
Also, please upgrade to the latest version if you can.
2156
1359
1150
462
