Discovery Import
Discovery Import
    • rg
      Hello
      I believe there is a bug, there are no more coordinates of the ordinates and clicking on the arrow of the select command no longer exits the menu with the various selections
      Best Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Hello Robert ,
      I tried doing it on my end and I have attached the video of me doing it (Let me know if I understood it right). Although I will bring this to concerned people's notice, and get back to you as soon as possible.
    • rg
      Charudatta Bandgar Hi
      It is correct you understood correctly, that menu does not come out of me.
      Could it be because I also installed the previous version?
      Best Regards
        Hello Robert ,
        Even I have previous versions installed, I am not sure whether that is an issue, but I will still bring that to their notice and confirm whether that could be the probable cause.
        Regards.
    • rg
      Hi
      thanks
      Best Regards
    • rg
      Hello Charudatta Bandgar
      do you have any news about the problem?
      The problem is occurring to several customers
      Best Regards
        Hello Robert ,
        I still do not have any concrete information since the issue was not observed otherwise and we were not able to recreate it too, I will get back to you once I get to know anything.
        Sorry for the inconvenience.
      Hello Robert ,
      Sorry for the delay.
      The issue is unusual but upon further investigation I realised that it is due to the language setting. For some reason if I set the language to Italian, I am facing same issue. I am in conversations with the developement team, will try to find a workaround, and if there isn't I will file a bug report and update you accordingly (so that it can be addressed in future versions).
      For now if it is possible for you, please use the default English.
      Regards.
    • rg
      No problem for the late reply, thank you for your availability
      Best Regards
        Hello Robert ,
        I discussed this issue with the developers, and it indeed is a bug. Hence I have filed a bug report (Bug ID: 329649).
        Although this workaround is not very convenient and viable, you can change the language to English/default while using the ordinate dimension feature.
        Regards.
    • rg
      Thanks for the answer, for now until the BUG is corrected I will make customers use the English language
      Best Regards
        Thanks, Robert
      Hello Robert ,
      This behavior is not observed in other languages tested, just with Italian UI. It will be fixed in the next release version. Thanks for bringing it to our notice.
      Regards.
      • rg
        Charudatta Bandgar Thank you very much
      • rg
        Charudatta Bandgar Hello
        The problem still persists SpaceClaim 2021R1
        Best Regards
        Hello Roberto
        I have noticed that too, the bug was expected to be resolved. I have reopened the ticket and I am in conversations with the developers. Also followed in this post.
        Regards.
Viewing 8 reply threads
