August 2, 2018 at 10:38 pm
Maxwell
SubscriberHello,
I was trying to add a force reaction probe result in Mechanical using ACT.
I set it up to look for contact regions and everything is working well so far.
But when I am trying to use "ForceReaction.ContactRegionSelection" to
set up the target contact, it just does nothing, also not giving me any error.
But whenever I chose a contact region manually, I also got a contact region back
when entering "ForceReaction.ContactRegionSelection" in the console.
Is this a bug or is there another way to set up the location for the probe with ACT?
Thank you!
August 6, 2018 at 7:09 pm
Aniket
Ansys EmployeeYou may want to try it as follows:
ForceReaction.InternalObject.BoundaryConditionSelection=contactobject.ObjectId
August 6, 2018 at 10:17 pm
Maxwell
SubscriberOh perfect, exactly what I needed.
Thanks a lot!
November 7, 2019 at 8:33 pm
jehanzeb
Subscriberfacing same problem please guide me to
November 7, 2019 at 9:32 pm
Maxwell
SubscriberWell, if you named your contact e.g. "ContactName", you could just use:
ForceReaction.InternalObject.BoundaryConditionSelection =
ExtAPI.DataModel.Tree.GetObjectsByName("ContactName")[0].ObjectId
That's how I solved it before.
2110
1335
1110
461
