February 17, 2023 at 9:32 am
Roberto
Subscriber 🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsIn version 2022-2023R1, when geometry is selected from a mirror, the parallelepiped of the selection is not seen
February 17, 2023 at 9:40 am
Devendra Badgujar
Forum ModeratorHello Roberto
Let me check this and get back to you.
Regards.
February 17, 2023 at 10:29 am
Devendra Badgujar
This looks like a normal mirror operation for me, unless I'm misunderstanding. If you select the line as mirror, it will set that as mirror plane.
Can you please confirm how exactly you would like to have the mirror operation to work?
Regards.
February 17, 2023 at 10:38 am
Roberto
SubscriberHello Devendra Badgujar
The functioning of the mirror works, but when I select the box does not come out as in the attached video to understand what I select , the selection square does not come out
Regards
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
February 17, 2023 at 10:54 am
Devendra Badgujar
Forum ModeratorRoberto
Ok, I understand it now. I can reproduce that problem.
Let me check with the team and will get back to you.
Thank you.
March 8, 2023 at 12:51 am
Devendra Badgujar
I have raised a bug 796125 for this issue. I will let you know as I get more information on this from the development team.
Thank you.
March 15, 2023 at 12:59 pm
Devendra Badgujar
Forum ModeratorRoberto The bug will be fixed in the SpaceClaim 2023 R2 release.
Regards.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
