Discovery Import
Discovery Import
bug report on Spaceclaim 2022 R1
    • stefano.caselli
      I found a bug on Spaceclaim 2022 R1 with Italian laguage frontend:
      In the DETAIL ribbon, menu under DIMENSION doesn't work (the pointing down arrow is not clickable so, the menu does not appear).
      Same sort for SELECT, both in DETAIL ribbon and DESIGN ribbon.
      That bug not affect english language of the frontend. Spaceclaim in english works flawlessly.
    • Devendra Badgujar
      Hi Stefano Caselli
      Let me check this and get back to you.
    • Devendra Badgujar
      Hi Stefano Caselli
      Thanks for bringing this to our notice, your observation is correct. I tried it on my end and was able reproduce it.
      I have filled a Bug ( 586164 ) for this issue and will let you know as soon as I hear back from the developers.
      Regards.
    • ventura
      Please fix it soon... we had this bug before and it was fixed in the last 2021 version... now the bug appear again... is since 2020 we have this problem in Italian language.
      See this:
      Functional problem and mistranslation
    • Devendra Badgujar
      Hi Stefano Caselli DrkAngl
      The problem is fixed in the version 2022 R2.
      Regards.
Viewing 4 reply threads
