Discovery Import
Discovery Import
Bug Report – Spaceclaim 2020 R2
    • don
      Spaceclaim 2020 R2; You can no longer select a smart hole as the "Up To" point of the mating hole. If you try and select the center mark of the smart hole, it wipes out your counterbore.
    • Charudatta Bandgar
      Hello Don Lewis ,
      Thanks for bringing this to our notice, I will try doing this on my end as per my understanding of the problem you are stating and if we confirm the bug, I will file a report and update you with the bug ID.
      Regards.
      Hello Don Lewis ,
      I tried recreating your query, and I did not face the issue you are facing. I have attached a video, of me doing it.
      If this is not what you were trying to do, can you please share the files and/or screenshots with a generic model?
      I did not understand this particular issue.
        Regards.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • don
      Charudatta,
      If I use the popup menu to select "Up To" it seems to work, but if I use the hotkey I get a completely different result.
        Hello Don Lewis ,
        Which hot key are you using (Since it was not clear from the video you have sent)?
        Regards.
    • don
      U
        Hello Don Lewis ,
        That is an unusual behavior (since it worked on my end), can you check the customize command shortcut assigned to "U"?
        If it is correct and you are still facing an issue, I will have to discuss it with concerned people and get back to you.
      • don
        Charudatta Bandgar
        There is no customization applied to U.
        Hello Don Lewis ,
        It is possible that U might be assigned to some other operation, can you please 'Add' or 'edit' shortcut for U? Make it 'up to'. Let me know if that works.
      • don
        Charudatta Bandgar
        Hello Don Lewis ,
        That is unusual behavior, I will discuss it with the experts and get back to you with the information.
        Regards.
        Hello Don Lewis ,
        Is this problem specific to a model or you are facing it for all the files?
        If it is file specific, can you share it with us?
        Regards.
      • don
        Charudatta Bandgar I created the file I used in the video example specifically to show the problem, so no, it is not file specific. (See attached)
      Hello Don Lewis ,
      Although this behaviour is not very frequently seen for other customers, I have filed a bug report (Bug ID: 317091), to bring this to developers notice. I will let you know if I get to know more regarding this. Until then you can use the   tool, if that is working for you.
      Regards.
      Hello Don Lewis ,
      Can you please follow below-mentioned steps and send me the journal file folder along with the log files,
      Steps:
      1. Open a new session of SpaceClaim, open the file, and go through the steps where it fails.
      2. Exit SpaceClaim
      3. Open a File Explorer window and type: %appdata%.
      4. Go to the SpaceClaim folder, and then find the Journal File folder (it should look something like the image attached with your user name):
      5. Send the latest journal file associated with the session from step #1 above.
      6. Get the latest log file: (i.e. C:Users...Customer...AppDataRoamingSpaceClaimLog Files) and send them.
      Thanks in advance and apologies for the inconvenience.
    • don
      See attached.
Viewing 7 reply threads
