November 9, 2018 at 4:01 pm
kjang8
SubscriberHi, all.
I have a simple box type building geometry.
I just model it with a simple surfaces.
And I wanted to apply mutiple wall materails on it with given informations.
Such as
Material,
B5 - 1 IN DENSE INSULATION, !- Name
VeryRough, !- Roughness
2.5389841E-02, !- Thickness {m}
4.3239430E-02, !- Conductivity {W/m-K}
91.30524, !- Density {kg/m3}
836.8000, !- Specific Heat {J/kg-K}
0.9000000, !- Thermal Absorptance
0.5000000, !- Solar Absorptance
0.5000000; !- Visible Absorptance
Material,
C12 - 2 IN HW CONCRETE, !- Name
MediumRough, !- Roughness
5.0901599E-02, !- Thickness {m}
1.729577, !- Conductivity {W/m-K}
2242.585, !- Density {kg/m3}
0.6500000, !- Solar Absorptance
0.6500000; !- Visible Absorptance
But I just wondered what is the best way to apply this information to this surface.
Should I suppose to model this in details?
If so, how?
Please guide me if you can.
Thanks.
November 12, 2018 at 7:37 am
seeta gunti
Ansys EmployeeYou can use shell conduction and give multiple thicknesses and material properties but can not be defined all the properties.
Seeta
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2508
2064
1279
1088
456
