November 21, 2019 at 9:33 am
ebrahem
Subscriberi m calculating bulk temperature or mixed mean temperature of fluid in a 2D domain for that i have to create surfaces
channel height is 3mm and length is 31mm
to create line surfaces i m using scheme file to generate them
(Do ((x -0.004 (+ x 0.0005))) ((> x 0.0271))
(Ti-menu-load-string (format #f "su line-surface x=~a ~a -0.0015 ~a 0.0015" x x x))
similar method to create points on wall
at these lines i will calculate Tb and at points on wall i will calculate Tw to use them in Nu calculation
my procedure is simple plot these lines write ascii files with the information of velocity and temperature then by using the matlab i am calculating the bulk temperature to calculate Nusselt number.
i m wondering if someone can guide me that how i can skip matlab and calculate it with fluent only for transient run
as saving data for whole transient run in ASCII format and post process it in matlab is little bit time and storage space consuming
the formula for bulk temperature calculation is similar as discussed in this forum previously i.e. fluent validation for heat transfer.
i hope someone can help me in this regard
November 21, 2019 at 3:30 pm
Ansys EmployeeHave a look at the monitors: points and volume for Fluent. Add in Custom Field functions and I think you're there.
November 22, 2019 at 5:07 am
ebrahem
Subscriberif i may share the procedure here so that u can guide me or correct me if i m doing somehing wrong
i have made the CFF of total temperature*velocity magnitude and named it tu then i make the monitor on the line surface where i take the integral of tu similarly i made the CFF of velocity magnitude and named it u again i make the monitor on line surface and calculate the integral of u
for calculating wall temperature i make the point surfaces and calculate the vertex average of wall temperature on the points.
(Do ((x -0.004 (+ x 0.00001))) ((> x 0.02701))
(Ti-menu-load-string (format #f "su point-surface point-~a ~a 0.0015" x x))
(Ti-menu-load-string (format #f "s m su set tw~a ~s temperature point-~a () no no yes tw~a 1 yes flow-time" x "Vertex Average" x x))
(Ti-menu-load-string (format #f "s m su set tu~a ~s tu x=~a () no no yes tu~a 1 yes flow-time" x "Integral" x x))
(Ti-menu-load-string (format #f "s m su set u~a ~s u x=~a () no no yes u~a 1 yes flow-time" x "Integral" x x))
i dont know how to calculate the Tw -Tb from fluent by adopting above procedure
one more thing fluent become heavy by creating all those surfaces and it also skip some point and line surfaces by showing error
any help is appreciated
below is the image that shows the lines and points for straight channel in low resolution in actual i m making 1000 of lines and points to increase the resolution
November 22, 2019 at 9:28 am
Ansys EmployeeUsing an average value on a line will reduce the need for points. Then have a look at the various report options and expressions. You may be able to do something clever with parameters and report functions. With 2020R? I think you'll be able to use Expressions for some of this too: can't remember quite what/when stuff is coming.
November 22, 2019 at 3:10 pm
ebrahem
Subscriberif u can share any working example then it will be highly appreciated
November 25, 2019 at 11:24 am
Ansys EmployeeMonitor points & reporting on lines/surfaces is covered in some of the tutorials. You'll find the public tutorials in the Help system, or YouTube videos may well cover reports.
November 25, 2019 at 1:44 pm
ebrahem
SubscriberPlease correct me if I am wrong
First I have defined CFF of total temperature × velocity magnitude
Then I defined CFF of velocity magnitude
Next I have made the report function i.e. integral of tu on the interior domain
And similarly integral of u on the interior domain
Next I make the CFF of report definition 1/ report definition 2
And finally make the report definition of new CFF (here I don't know on what surface I have to make it )
Please guide me in the light of above formula have I missed something as in the above mentioned formula we have to find the value as a function of T( x,t ) -
November 25, 2019 at 4:41 pm
Ansys EmployeeYou need to work out what you're trying to calculate and check the maths: I'm just going to give you pointers on how to do something.
5162
3275
2447
