February 17, 2021 at 3:57 pm
milasaga
SubscriberI'm using the burst (electrical fast transient) generator from Nexxim Circuit Elements.
The waveform I get is not identical from the EN61000-44 standard. It has a negative damping that is not mentioned in the standard.
This is what I get:
February 22, 2021 at 12:27 pmrtk
Ansys Employee,nCould you please try replacing that interface port with a voltage probe and measure the same?nHope this addresses your concern.nnBest Regards,nFebruary 24, 2021 at 9:21 ammilasaga
SubscriberHello Array ,nThank you for your help nUnfortunately, I get the same result with the voltage probe:nnI guess I'm doing something wrong since it's a standard based component and the output should be the same as described in EN61000-4-4 standard (without the negative damping)nnI cannot find any documentation about this component (besides the Component Help with the right-click on the symbol) or any EMC tool from Nexxim Circuit Elements library, do you know any place where I can find some tutorial or help?.Thank you for your time,nn
- Maxwell, HFSS or Q3D?
- Error
5162
3275
2447
