Ansys Products
Ansys Products
busy error
    • Semanur Erbay
      The program did not open when 2022 was installed. I uninstalled and installed the 2023 version. this version opens but it always says busy
    • George Karnos
      What happens if you open Workbench by right-clicking on Workbench in the Start Menu and
      choosing "Run As Administrator"
      Also, check your virus scanner and firewall software for items being blocked.
      • Semanur Erbay
        I accidentally activated the keep updates on feature when I installed it before. now i reinstalled it and the screen looks like this. Where can I do the update settings? I tried what you said, it doesn't work. "next" button is not active.
    • George Karnos
      Click on Exit
      • Semanur Erbay
        yes, i did
    • Mangesh Bhide
      Hello
      When you were seeing this error, were you launching “Workbench” or “Mechanical” ?
      the hung installation – if it is still active, what is the last line seen when you click View Detailed progress log ?
      any of the below ?
      Creating Start Menu Shortcut for ARC 2023 R1 Configuration…
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\ARC Configuration 2023 R1.lnk
      Creating Start Menu Shortcut for DCG 2023 R1 Configuration…
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\DCG Configuration 2023 R1.lnk
      Created Shortcut C:\Program Files\Ansys Inc\v231\RSM\bin\HPCServices\DCG Local Portal.lnk
      Created Shortcut C:\Program Files\Ansys Inc\v231\RSM\bin\HPCServices\DCG Local Shutdown.lnk
      Running C:\Program Files\Ansys Inc\v231\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
      Configuring LS-DYNA …
      • Semanur Erbay
        none of them
    • Semanur Erbay
      please help
Viewing 4 reply threads
