C-D Nozzle Analysis
    • Ka Ki Yuen
      I want to see the flow on the downstream side of the nozzle, so I draw a big square behind the nozzle (not sure if it is correct). But the flow pattern is not right. Here's my setting:
      1. Inlet static pressure: 101325Pa; Inlet total pressure: 120192.9955Pa  (based on Mach=0.5); Inlet temperature: 293K; Ai/A*=1.34
      2. From the geometry, Ae/A*=1.675, so from isentropic flow table (supersonic condition), pressure on exit plane: 15576.84Pa, temperature on exit plane: 171.61K; Expected mach is 1.99~2
      3. the nozzle is build in accordance with Ai/A* and Ae/A*
      In the result, I don't have any flow pattern, and the mach-contour is all in blue.
      Please advice, thanks!!!
      A velocity field image (not Mach Number) might help. What is the gas density? Is this 2d or 2d-axisymmetric?
    • Ka Ki Yuen
      when I delete the huge rectangle, I can get nice result, although it was inconsistent with my calculation.
      FYI: for air, I set it as ideal gas
    • Ka Ki Yuen
      and yes, 2D- axisymmetric
      Picture please. As a guess your initial condition isn't very good. With pressure in & out the mass flow becomes part of the solution, and with ideal gas that'll get even messier. What is your operating pressure?
    • Ka Ki Yuen
    • Ka Ki Yuen
      this setting is sightly different from what i've post but if i put this setting to the model with big rectangle, is doesn't work too
      without the rectangle, the contour is like this
      With the box the core downstream of the nozzle will be moving, but the remainder of the region won't.
    • Ka Ki Yuen
      sorry I am new to ANSYS, didn't catch you quite well...so if I wanna investigate the flow behind the nozzle (oblique shock or expansion wave), how could I set up the simulation? I've read some articles, they have something like this:,
      but I have no ideas how to setup this properly...
      As you have been, but you may need to patch a higher velocity region in the jet zone.
Viewing 9 reply threads
