December 1, 2020 at 7:33 am
daniel.nouxet
SubscriberHello,
I have to verify before launch a function if a point on a cuve or on an edge is available.
I start with the Sample exmple, PolygonMesh.cs:
protected override void OnUpdate(Command command) {
command.IsEnabled = Window.ActiveWindow != null && Window.ActiveWindow.ActiveContext.SingleSelection is IDesignBody;
}protected override void OnExecute(Command command, ExecutionContext context, Rectangle buttonRect) {
Window window = Window.ActiveWindow;
if (window == null)
return;var desBody = window.ActiveContext.SingleSelection as IDesignBody;
if (desBody == null)
return;DesignBody desBodyMaster = desBody.Master;
But I don't understand.
I try to undertand thanks to theAPI, but the description are to light for me.
Could you give me explanation ?
Regards.
December 1, 2020 at 10:07 am
Naresh Patre
Ansys EmployeeHello dNouxet
Help on API is available in the SpaceClaim_API.chm located in C:Program FilesANSYS Incv202scdmSpaceClaim.Api.V20 folder. There are some other library documents in this folder that you can check out. Other than this, I don't think there is any other documentation available.
- The topic ‘C# selection context’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8832
4658
3159
1688
1482
